nodigital 0 Posted December 30, 2020 PAM Luminor Marina, bought years ago from Silix and from new had problems with loose screw pins for the strap. Tightened them up and they rapidly came lose. One day I had the bright (Now very dim) idea that I could add a tine drop of thread lock to them and yup, solved the problem. Came to change the strap and that thread lock has turned into stud lock. I couldn't unscrew them, eventually stripping the screw heads. Had to cut the old strap, dremel cut the barrels and pins then try to remove the stuck part of the pin with plyers. Didnt work and instead sheared off the pin at where the thread starts which has left me with a big problem. With a regular springbar in the new strap it wont hold. its fine for a time but the springbar moves horizontally and moves out to the open end and the strap comes off. Only options I see are: Drill out the thread - dont know what would go in here to hold in the strap, any thoughts? Dont think I could retap a new thread New case - Any idea who could supply one? Thanks Share this post Link to post Share on other sites
BadApple 13,081 Posted December 30, 2020 Drill out as best you can and get spring bars..... https://www.ebay.co.uk/itm/22-24-26-mm-Springbars-for-PANERAI-40-44-47-mm-Watch-Pins-Screw-Tube-Lugs-Bars/271746941648?hash=item3f456142d0:g:r0kAAOSw-W5UvXs~ Share this post Link to post Share on other sites
nodigital 0 Posted December 30, 2020 Excellent, many thanks for the swift reply and suggestion . Share this post Link to post Share on other sites
Simonix 8,660 Posted December 30, 2020 16 minutes ago, nodigital said: Excellent, many thanks for the swift reply and suggestion . It’s worth noting that those springbars Badapple posted a link to, are slimmer on one side too. This means you don’t have to drill out the threaded side too much. Just put the “thin end” in. 1 Share this post Link to post Share on other sites
