5teve 112 Posted April 28, 2021 I would have just gone all the way through the spring bar,but away from the case.If I’m reading what your trying to do correctly your still hoping to remove it as a spring bar should be used,but your tube is still 20mm in a 20mm gap.I know you said the bracelet gap is 1.7mm but if you went down with a 2mm milling cutter more towards the gold centre link it wouldn’t affect your bracelet should you want to re fit it.Tis would then create 2mm of clearance to push the spring bar over,I bet you would only have to do one side on each bar. Share this post Link to post Share on other sites
Popperini 17,778 Posted April 28, 2021 21 minutes ago, splke said: Don't worry pal no one ever sees the underside of a watch With the exception of potential buyers There's two things here. 1. It doesn't matter if I can't see it - any sort of self-inflicted damage or cock-up haunts my waking and sleeping hours until it's sorted. This is yet another of my myriad OCD quirks... And 2. Although I've got no intention whatsoever of selling this, I'd still want to sort out the totally trapped bracelet before it passed to anyone else. And once I discovered the problem I felt compelled to deal with it. 1 Share this post Link to post Share on other sites
Popperini 17,778 Posted April 28, 2021 2 minutes ago, 5teve said: I would have just gone all the way through the spring bar,but away from the case.If I’m reading what your trying to do correctly your still hoping to remove it as a spring bar should be used,but your tube is still 20mm in a 20mm gap.I know you said the bracelet gap is 1.7mm but if you went down with a 2mm milling cutter more towards the gold centre link it wouldn’t affect your bracelet should you want to re fit it.Tis would then create 2mm of clearance to push the spring bar over,I bet you would only have to do one side on each bar. I'm happy to destroy the spring bars - I don't care how much damage they sustain or how I get them to come out, I did intend to drill right through them, but I take your point about the fact the bars are 2mm and I'm not cutting them in half with a smaller bit. However, if I use a 2mm bit, then it's going to create a 2mm hole in the SEL's springbar access slot, which is only about 1.7mm wide, and I wanted to avoid damaging to the SELs. But it's too late for that now anyway as drill creep has already nibbled into the edges. So I may indeed go all-in and use a 2mm cutting bit to get right through the bars. I'll probably end up replacing the SELs or rebuilding them with new outer sections. Share this post Link to post Share on other sites
GingerApple 7,272 Posted April 28, 2021 3 minutes ago, Popperini said: or rebuilding them with new outer sections. Kindly tag me in the 'rebuilding thread' too - I'd hate to miss more comedy, 4 Share this post Link to post Share on other sites
5teve 112 Posted April 28, 2021 (edited) 0.3mm bigger you wouldn’t even notice,it’s only 0.15 a side as I said more towards the gold centre links centered up nicely would look fine.If you do go this route I would try to clamp the bracelet up just in case the cutter grabs as it breaks through the spring bar tube. Edited April 28, 2021 by 5teve Share this post Link to post Share on other sites
Waspy 306 Posted April 28, 2021 10 hours ago, TheGingerFerret said: Kindly tag me in the 'rebuilding thread' too - I'd hate to miss more comedy, 2 Share this post Link to post Share on other sites
GenTLe 1,490 Posted April 28, 2021 22 hours ago, Glaude said: Isn't there some general rule that you can't befriend a dentist or something like that ? It depends. Let me introduce you Nicole Minetti, former "dental hygienist" () of Mr. Berlusconi... This one, together with the famous Maroccan girl "nephew of Egyptian Mubarak" (), Karima El Mahroug aka "Rubi Rubacuori" (Rubi Heart-stealer), 17yo at those times: 2 of the starrings of the "bunga bunga" nights... (https://en.wikipedia.org/wiki/Bunga_bunga) Share this post Link to post Share on other sites
Glaude 1,615 Posted April 28, 2021 1 hour ago, GenTLe said: It depends. Still don't need to be friends ... chloroform is cancerous but there are other substances alike ... 1 Share this post Link to post Share on other sites
Popperini 17,778 Posted April 29, 2021 9 hours ago, GenTLe said: It depends. Let me introduce you Nicole Minetti, former "dental hygienist" () of Mr. Berlusconi... This one, together with the famous Maroccan girl "nephew of Egyptian Mubarak" (), Karima El Mahroug aka "Rubi Rubacuori" (Rubi Heart-stealer), 17yo at those times: 2 of the starrings of the "bunga bunga" nights... (https://en.wikipedia.org/wiki/Bunga_bunga) This post needs to be moved to the “Eyecandy and Wristworkouts” section. 2 Share this post Link to post Share on other sites
GenTLe 1,490 Posted April 29, 2021 8 hours ago, Glaude said: chloroform is cancerous but there are other substances alike ... "If you can't seduce her, you can sedate her" 1 Share this post Link to post Share on other sites
Nikosaldente 630 Posted May 2, 2021 On 29/04/2021 at 01:23, Glaude said: Still don't need to be friends ... chloroform is cancerous but there are other substances alike ... We stopped using chloroform ages ago for that reason.... Also, I have many friends, you don't want a person handling sharp rotating instruments inside your oral cavity to consider him an enemy On 28/04/2021 at 03:28, NCRich said: You scare me. The Dentist I went as a child was scary, I'm like Disney Club compared to him 3 Share this post Link to post Share on other sites
Nikosaldente 630 Posted May 2, 2021 On 28/04/2021 at 23:41, GenTLe said: It depends. Let me introduce you Nicole Minetti, former "dental hygienist" () of Mr. Berlusconi... This one, together with the famous Maroccan girl "nephew of Egyptian Mubarak" (), Karima El Mahroug aka "Rubi Rubacuori" (Rubi Heart-stealer), 17yo at those times: 2 of the starrings of the "bunga bunga" nights... (https://en.wikipedia.org/wiki/Bunga_bunga) Would love to have her as an assistant 1 Share this post Link to post Share on other sites
movintage 2,310 Posted May 2, 2021 Unbelievable! This was started 8 or 9 days ago and still at it, Since the damage is already done, get on with it. Finish cutting the end links, remove the spring bars and bracelet and fix file, sand and polish the lugs and replace the SELs, get a new TT or put on the Jubilee you have and live with it. Share this post Link to post Share on other sites
George. 34 Posted May 2, 2021 Can’t you just... you know.... pull the bracelet really fucking hard? like, reeeeeeealy hard? Share this post Link to post Share on other sites
GingerApple 7,272 Posted May 2, 2021 1 hour ago, movintage said: Unbelievable! This was started 8 or 9 days ago and still at it, Since the damage is already done, get on with it. Finish cutting the end links, remove the spring bars and bracelet and fix file, sand and polish the lugs and replace the SELs, get a new TT or put on the Jubilee you have and live with it. He started his (still unfinished) Omega Snoopy about a year ago - you're being wildly optimistic. 1 Share this post Link to post Share on other sites
k4jun 251 Posted May 2, 2021 On 28/04/2021 at 22:41, GenTLe said: Nicole Minetti, I came here to see whether Popps has damaged/released the bracelet but somehow Nicole has stolen all my attention 2 Share this post Link to post Share on other sites
Popperini 17,778 Posted May 2, 2021 3 hours ago, movintage said: Unbelievable! This was started 8 or 9 days ago and still at it, Since the damage is already done, get on with it. Finish cutting the end links, remove the spring bars and bracelet and fix file, sand and polish the lugs and replace the SELs, get a new TT or put on the Jubilee you have and live with it. Thanks for the motivational pep talk, but you clearly don’t know how I go about things. Ginge, on the other hand - he knows how I roll. I roll very, very slowly - with lots of meandering along the way. Share this post Link to post Share on other sites
GenTLe 1,490 Posted May 2, 2021 8 hours ago, Nikosaldente said: Would love to have her as an assistant Not sure your wife will agree, but yes, that can also be a great business pusher Share this post Link to post Share on other sites
movintage 2,310 Posted May 2, 2021 2 hours ago, Popperini said: Thanks for the motivational pep talk, but you clearly don’t know how I go about things. Ginge, on the other hand - he knows how I roll. I roll very, very slowly - with lots of meandering along the way. No worries, I totally get it. Procatzione di Popperini! 1 Share this post Link to post Share on other sites
k4jun 251 Posted May 5, 2021 Seems to be a popular problem recently... even for the professionals from the gen side AD Installed Shoulderless Spring Bars in BB58... 2 Share this post Link to post Share on other sites
GingerApple 7,272 Posted May 5, 2021 How is this going now Poppadoodle? Long since sorted I assume? Share this post Link to post Share on other sites
GenTLe 1,490 Posted May 5, 2021 These no-shoulder steel springbars are worse (much worse) than those stupid "inverted springbars" I had to deal with recently on a 1950 something Zenith... These bastards "Female springbars": Used on these kind of lugs: They were made of brass and totally oxidized so not moving at all, luckily the strap was complete crap, so I could just cut them in half (through the strap)... Share this post Link to post Share on other sites
Popperini 17,778 Posted May 5, 2021 1 hour ago, TheGingerFerret said: How is this going now Poppadoodle? Long since sorted I assume? Oh yes, of course. Well, I had another go at carefully drilling into the bars - but I'm still attempting to avoid damaging the SELs' access slots too much, which makes the job nigh on impossible. One end of the bracelet is tantalisingly close to moving, but the SELs are so damn tight that it just won't be wiggled free. And the only way I could force it free by levering it out would be by forcing a tool between the SEL and the case, which would damage the case. It's looking increasingly like I'll have to attack the bars with a 2mm bit, and chew chunks out of the SEL slots in order to cut right through the bars. It really is a right bugger of a job. So I've done my usual in this situation, and I'm ignoring it for a while, hoping I'll wake up and find it was all a dream. @k4jun Thanks for the link - I just read that Tudor thread, and LOLed at the "experts" there chipping in with advice to insert this or that implement which will magically sort out the problem. I've subscribed to that thread - I really want to hear how that one turns out! 1 Share this post Link to post Share on other sites
brang1 3,988 Posted May 6, 2021 Have you tried the Lord Popp? “Listen to me, Lord, and answer me, for I am helpless and weak. Save my watch from death, because I am loyal to you; save me, for I am your servant and I trust in you. You are my God, so be merciful to me; I pray to you all day long. Make your servant glad, O Lord, because my prayers go up to you. You are good to us and forgiving, full of constant love for all who pray to you. Listen, Lord, to my prayer; hear my cries for help. I call to you in times of trouble, because you answer my prayers…” 1 Share this post Link to post Share on other sites
