Kangol 0 Posted August 4, 2015 Hi I have just received a Rolex DSSD from Toro which looks lovely. I needed to take a couple of links out of it and bought some tools this morning. I managed to undo two screws and remove a link but still need to remove at least one more link. The problem is no other screws will undo. They come out about 2mm but then get really tight won't come out any further. I have tried screwing them back in and out again but they still get stuck on the way out. Has anyone else ever had this problem and got any tips? Thanks K Share this post Link to post Share on other sites
Mattcrx 8 Posted August 4, 2015 Make sure they are unscrewed totally and then use a pair of needle nose pliers just grab the screw shaft and with abit of force they will slide out Share this post Link to post Share on other sites
Kangol 0 Posted August 4, 2015 That's the problem, they stop turning and won't come out any further. The two screws I did manage to do were fine and i used pliers once they were loose but the rest seem to get totally stuck - won't turn any more and won't pull out. Share this post Link to post Share on other sites
Mr_B 2,407 Posted August 4, 2015 Soak the bracelet in some wd40 Share this post Link to post Share on other sites
greg_r 83 Posted August 4, 2015 WD40 or try using a hairdryer on the threaded side of the link (take the bracelet off the watch first!). A little heat will often help free these things. Share this post Link to post Share on other sites
Gazzla 23 Posted August 4, 2015 Take the bracelet off and soak in Baby Oil. Works for me! Share this post Link to post Share on other sites
Kangol 0 Posted August 4, 2015 Thanks. How does the bracelet come off the watch face? Share this post Link to post Share on other sites
jaychizum 0 Posted August 13, 2015 Read the thread regarding how to do a quality inspection on a rep when it first comes in, just some tips there. However I'd get a very fine cloth to place around it first then use fine pliers or needle nose. WD40 is your friend. Share this post Link to post Share on other sites
ElvisFreak 73 Posted August 13, 2015 oh damn... that's it sir, you're stuck being screwed Share this post Link to post Share on other sites
