gtwc
A6497 - intermittent problem, help wanted !!!!!
gtwc
I have an A6497 in one of my Pam reps (not the newer platinum plated one) that works fine when the watch
is lying flat on a table, face up or face down.
When I strap the little sucker to my wrist, the little sucker stops. Almost every time. Nearly as regular as
clockwork. It can be re-started by tapping either end near the lugs. H'ever, unless you are constantly
checking the time every second available, you are going to miss a tap or 2 and it stops.
Take it off, swap watches, and watch it work perfectly as a desk ornament or paperweight.
Any suggestions / ideas? I am not technically minded but I do have a set of Pam caseback
openers if the fix is EXTREMELY SIMPLE !!!
Look forward to a helpful reply...................................
gtwc
bump, bump etc.
Somebody please offer advice / help or should I call the Samaritans?
pollux1
Hopefully one of the modders can help mate, I had a similar problem and it was nothing more than dust in the movement, a quick blow out and it was fine. I would still suggest you get someone to look at it for you if you aren't proficient at fixing them. :)
Corv99
free bump !!
can't help with your problem I'm afraid...
whats sort of cats are they? Siberians?
gtwc
free bump !!
No, Maine Coons (thanks for asking)
Luthier
Shoot PM to Mike.
gtwc
Shoot PM to Mike.
thanks Luth, will do......
