gianton 14 Posted January 25, 2012 Today I couldn't wind my 202A, when I tried to wind it the crown keeps getting out and instead it changes the time. Movement is a Swiss ETA 6497-1 18.800 bph. What might be the problem? Share this post Link to post Share on other sites
dingle 57 Posted January 25, 2012 the screw that holds the stem in place is loose. Remove the back, push the stem all the way in and tighten the screw. If this does not help, it may be time for a new stem. Share this post Link to post Share on other sites
gianton 14 Posted January 25, 2012 Unfortunately the screwdriver I have it's not small enough to fit the screw. I guess I have to give it to my local watchmaker. Thanks for your help. Share this post Link to post Share on other sites
Member X 91 Posted January 25, 2012 You should be able to pick up some jewellers screwdrivers for cheap from the local market! Always handy to have Share this post Link to post Share on other sites
dingle 57 Posted January 25, 2012 You should be able to pick up some jewellers screwdrivers for cheap from the local market! Always handy to have +1 the RWG shop has some too Share this post Link to post Share on other sites
