Annie 0 Posted May 11, 2013 Hi i need some help on what type of tools and where can i buy them to remove the strap from Santos 100 ? I hope it is screws that is holding the strap to the watch as i can barely see if it is screw or a pin. Thank You. Annie. Share this post Link to post Share on other sites
TheInthusiest 0 Posted May 11, 2013 This is all i could find. http://www.replica-watch.info/vb/archive/index.php/t-92255.html you might be out of luck... :( (Unless you dont care about a crap load of scratches and damages. :P ) Share this post Link to post Share on other sites
Annie 0 Posted May 11, 2013 This is all i could find. http://www.replica-watch.info/vb/archive/index.php/t-92255.htmlyou might be out of luck... :( (Unless you dont care about a crap load of scratches and damages. :P ) Thanks so much. But I am confuse some said pin some said push bar and some said screws ... Share this post Link to post Share on other sites
yawn 122 Posted June 2, 2013 You need to untight the screw and then use a push pin to push the spring bar out. Took me several hours to figure out. Share this post Link to post Share on other sites
Serge D 0 Posted June 2, 2013 On my wife santos its two bars. And you just push them out from one side. Har to explain but once you push with a needle or maybe you have iPhone simcard remover. Good luck! Share this post Link to post Share on other sites
