overclockedpc 0 Posted October 3, 2013 (edited) Rolex 16622 yatch rep....the pin between the first link of the band and the second fell apart and one of the pieces got lost. Is there anywhere I can order a replacement pin? It's a pin for one of the links that "can't" be removed. Edited October 16, 2013 by overclockedpc Share this post Link to post Share on other sites
TRANSPORTER 1 Posted October 3, 2013 Is it a split pin type if pin like these? If it is let me know the size in length and I can post you a few if you want ok Share this post Link to post Share on other sites
overclockedpc 0 Posted October 16, 2013 (edited) It's actually a spring pin for one of the "upper" links. The kind that you don't see when it's all together. Not sure quite how it happened, but the pin fell apart, and one "end" of the pin is stuck solid in the hole. I found the pin, but can't get it in because of the stuck piece :( :( :( It's one of these... The one end came out, and lodged itself in what I can only guess was leftover polishing compound. It's a shame, watch came from a trusted seller and not even a month later, this happens. Edited October 16, 2013 by overclockedpc Share this post Link to post Share on other sites
