themoo-12 0 Posted August 6, 2010 I've read that using a drop or 2 of synthetic oil on watch parts is quite effective. Anyone have any experience with this? I'm only familiar with grease for waterproofing thanks! Share this post Link to post Share on other sites
GC 4,517 Posted August 7, 2010 I believe there is a particular grade of oils specific for watch movts which are synthetic. If you are asking if you can use some other kind of oils for a watch movt I'm sure they would work but it is a very delicate process and just any synthetic (i.e. WD40...) would probably not produce an optimal result. Share this post Link to post Share on other sites
Brightlight 0 Posted August 7, 2010 As GC says you should only use oils recommended by the movement maker, either natural or synthetic. For details, see following - http://www.cousinsuk.com/PDF/categories/2_Oil_Chart.pdf If however you are talking about waterproofing seals, use silicon grease, it is easily obtained and is the correct thing. Share this post Link to post Share on other sites
themoo-12 0 Posted August 7, 2010 I'm trying to figure out the viscosity that is needed for the service hole on a sec@6 Share this post Link to post Share on other sites
Pepi 0 Posted August 7, 2010 My Dad always used Moebius oil http://www.ofrei.com/page246.html Share this post Link to post Share on other sites
