newtothisthing 0 Posted September 25, 2010 Is there a side by side comparision if these two watches? many thanks Share this post Link to post Share on other sites
trailboss99 997 Posted September 25, 2010 Nope, two very different watches. The DSSD is a far bigger watch, 4mm larger in diameter and much thicker with a ceramic bezel insert and blue lume. The SD is basicly the same as a Sub with no date and an HE valve. Col. Share this post Link to post Share on other sites
KBH 7 Posted September 25, 2010 Here's a DSSD and Sub. The Sub is basically the same size as the Sea Dweller but the SD is about 2 mm thicker. Mostly a thicker crystal. Share this post Link to post Share on other sites
newtothisthing 0 Posted September 26, 2010 Here's a DSSD and Sub. The Sub is basically the same size as the Sea Dweller but the SD is about 2 mm thicker. Mostly a thicker crystal. Thanks Share this post Link to post Share on other sites
