Duzza
HELP!!! TC Crystal HELP!!
Duzza
OK so I have my TC LV apart, all of 2 hours old! How the fuck do I get the crystal and gasket back in the retaining ring? in what order?? from what side??
Useless? I know!!!
Martijn0007
:giggle:
Good luck!
MetalMickey
That looks really complicated Try PMing PickledBeetroot, I am sure he can recommend someone to take a look :giggle:
Duzza
FFS :D
MetalMickey
If I tried that I couldn't even guarantee the cyclops would end up on the correct side.
Duzza
Someone must fucking know!!!
MetalMickey
Fine. I'll use Google for you...
http://www.replica-w...wer-crystal-mag
If you're not an RWI member give us a shout and I'll PM you the text and pics
The short version:
plankton
The short version:
Here you go.....
Duzza
Unfortunately thats a ceramic sub with different construction
MetalMickey
You're welcome
:fuck:
Here's some boobs
:boobies:
Genius
No it isn't
Duzza
No it isn't
Yeah it is :D
MetalMickey
No it isn't
Yeah it is :D
I have no clue. I'd just sell it and buy a new watch. I'll give you a tenner for the lot.
Why the fuck did you take apart a brand new watch anyway?
Genius
No it isn't
Yeah it is :D
Now I don't know if you're messing with me or not lol, it says 16610 on the bottom and its the old bent click spring.
And yeah why did you take a brand new TC sub to pieces
MetalMickey
No it isn't
Yeah it is :D
You having a go at his click spring?
Genius
No it isn't
Yeah it is :D
Of course not, I'm not a bigot, I welcome springs of all persuasions
MetalMickey
I think he means the link, which is a full dissassemble of a BP Sub-C. I was kind enough to click on and copy and paste two links from my Google search
Duzza
The link is to a ceramic sub, mine is a 16610
Genius
Ah makes sense now, I was too lazy to click the link just looked at the picture, picture is the old TC type
You may need a crystal / caseback press to get it back on tightly, I've got one somewhere that I havn't used in years that you could borrow if I can find it lol
Duzza
I have a press, just dont know what order to assemble the parts. Im guessing the gasket goes over the opening in the watch. But then does the crystal sit on top and then the retainer forced over it? Or do you fit the retainer and then the crsytal with the press?
Genius
I think there should be 2 gaskets one for the crystal one for the retainer, so it goes gasket - Crystal - gasket - retainer, that's how the expanded diagram shows it
Duzza
Expanded diagram is for a ceramic sub :) the 16610 only has 1 gasket
Genius
It definitely says 16610 on the bottom and shows the old click spring
Genius
I have seen a photo of the crystal sat in the retainer ring but off the watch so I think they may go together first, is that ring solid metal or is there a plastic gasket stuck in the inside edge?
MetalMickey
Can't you just leave the Crystal off and call it 'modded'?
That way you can change the time without having to unscrew the crown
