Duzza
HELP!!! TC Crystal HELP!!
Genius
Can't you just leave the Crystal off and call it 'modded'?
That way you can change the time without having to unscrew the crown
:rofl: You could tell everyone it's a new triple AR coating
Irishcain
Gasket goes in first, the crystal gets pressed down into it from the top.
Duzza
in to the retaining ring? then that goes on the watch?
Duzza
I dotn think that can be right, as the crystal just forces the gasket out, I think they need going on the case and then the retainer goes over the top?
justclark
The crystal should snap into the gasket. Push the crystal/gasket onto the watch case, align the cyclops, then use the press to push the retaining ring down over the entire assembly.
Genius
:thumbsup:
Duzza
Sense at last! Thank you!!!
Kleen™
"Goddammit Crystal; you are tearing us apart"
- Dollars
MetalMickey
Spoil sport
ssclassa80
I usually freeze my crystals for 30 min to contract the diameter a micron or two... Works wonders ime
watch101
In case you're wondering....this is how it looks when you don't take apart a new TC LV.....07011afd63c60e3197749503962f5637.jpg362067ca30fe529502f70c26c7a9987e.jpg
black263
Similarly, warm the case up to around 37 degrees C. I say that, because it's the temp you get if you keep it in an inside pocket next to your skin. That way, you know you won't cook the watch. Warm watch, cold crystal.
novnovi
is that the Tc insert? :huh:
watch101
It is. 3d4849a8ddc0c5ac29051a8cfcee75ea.jpg58d5add25fda9decd0cf52f3b7347846.jpgee1b4cb7b6410c0cca0600617db0096b.jpg44bc074f5ceb9262ca4c93e4f6ac459e.jpg
Duzza
That pearl looks nothing like the one on my TC LV.
watch101
How does yours look?
Daywatch
Good luck in getting it back together, there´s a crystal on m2m should You need it. Than pics of Your pearl please.
Thanks for the post, learned not to mess around with the domed crystals on the 5512/5513 to change them for a flat Clarks, guess I would never get it back together - and I don´t have a press anyway - unless I use the anvil in the garage.
Duzza
Heres my pearl, not easy to photograph.
watch101
I know it's hard to get a good focus on the pearl....the pictures don't actually do it justice in my opinion. It's better than it looks.
Duzza
Agreed it looks identical to a gen pearl to me. had them side by side.
watch101
Zoomed in - still doesn't do it justice. 41a11b6164a27bf44ee1022ab9ab9f2d.jpg
Duzza
TC and gen next to each other
novnovi
also on my insert was different, it was like Duzza's one..
Edited by novnovi
naidoo
may i ask
WHY THE FUCK DID YOU REMOVE IT!?!?!?!?!?!?
Duzza
may i ask
To put a genuine Rolex one in :)
