Duzza
HELP!!! TC Crystal HELP!!
MetalMickey
may i ask
WHY THE FUCK DID YOU REMOVE IT!?!?!?!?!?!?
To put a genuine Rolex one in :)
Ah, now that makes sense.
Pearl looks great, better than the gen!
dhistory
In case you're wondering....this is how it looks when you don't take apart a new TC LV.....07011afd63c60e3197749503962f5637.jpg362067ca30fe529502f70c26c7a9987e.jpg
is that the Tc insert? :huh:
That was my same thought...his pearl cup/holder looks too thick. What's going on here?
drmdtsap
so the right order is: put the crystal in the gasket, then on top of the watch, align the cyclops and then use a presser to push the retainer ring over the assembly? or am i missing something here?
Duzza
nope, thats exactly what you do
drmdtsap
Ok.. Just learning some stuff in case of an emergency... Thank you again Duzza
drmdtsap
Found this... maybe it will be a help to someone who messes up with the upper assembly of the watch. This article explains the rolex crystal gasket. At the end there is a video. Watch it. This is the first thing you must do, then use a crystal presser to put the retaining ring and that it should be it.
http://watchmakingblog.com/2013/05/05/a-quick-fit/
